971 Oil Pan
Fireman Dan
Evansville, IN
Getting to assembly my 440 and thought I had a 402 pan. Turns out I have a 971 and 933. Will the 971 work on Ebody? I have a skid plate on my k frame.
TIA
Daves69
ChiWest
Maybe some dimensions can help you...........
Fireman Dan
Evansville, IN
Wow! That will be very helpful. When I get in the house I’ll actually compare the two pans because I know the 402 is used quite often. At first class it looks like the 971 should work.
Thanks Daves69
hdwrench
western new york
going thru the same problem now ! i have a 971 pan and need a part numbers or source for the correct pickup tube …i’m converting from a truck oil pan with different pick up tube ,
pschlosser
Santa Rosa, California
I believe the 971 pan is a 5 quart pan, that will work in both B and E bodies.
@hdwrench And if you're planning to rev it over 5K, a windage tray and that extra quart on the aftermarket (440 source) six-quart pan (with matching pickup) may be a better option.
