A833 gearing too low
roadbuster
Anyone know what was done to my A833? I have a 3.55 8 3/4 rear end that I have been in to confirm and I am turning 3400 RPM @ 55MPH in 4th gear. I have 27in tires. Final drive of 1:1 should be about 2400RPM. So I figure I have about a 1.4 to 1 final drive. 1st thru 3rd gears are all low too. I have heard of over drive gearing, but under drive? Did someone change the gears so it would scream thru the quarter? Any advise?
Yes by my calculations you should be doing around 55 @ 2400 in 4th gear.
Only two things I can think of. Either your tack is off or your speedo is, or both but not likely.
May have to change the spedo gear.
