AAR Hood to Radiator support seal
Tom's EK2
Harlan, Indiana
I've seen some AAR's with the rubber hood seal and some without. I had to repair my fiberglass hood, so I don't have any holes in the front to mount this seal. What is the correct mounting and thoughts on if they came with this.
THANKS
don selleck
michigan usa
i have a pretty original FC7 it has that installed still, not 100% sure on that I'm sure someone here has one that is more documented than mine, and can verify. I can measure holes in the next couple days if necessary.
don selleck
michigan usa
That'll work!
Thank You
measurements are taken from left side of hood seal lays in channel except the 2 lower attachments, which are 6" from either side.
don selleck
michigan usa
the lower attchments are actually upper on the other side of the other 7, but I think you should be good, centered and laying in the channel
Tom's EK2
Harlan, Indiana
Excellent!
Could you give me one picture showing precisely where the seal lays/fastened to the hood?
