AAR painting process question
gtxno1
Freehold N J
Hi everyone working on my cuda all though I am not ready for paint I am moving along with my body work I am sure this question has been asked 1000x but I do not know the chain of events that need to take place such as what gets painted first the main color or the black also if the body color is first does the black go over color so on and so forth thanks
On my own 71 RT challenger. being 2nd owner since mid 70s. When prepping black portion of tail panel, there was no body color under blackout. But under the vinyl the roof was painted body color. As far as what was first I don't know. Also come to think of it there was no evidence of prime. I used lacquer thinner to clean things up and just wiped it off. can see blue on the edges.
70chall440
Western Washington
Are you asking how it was done originally or just how to do it? I am not exactly sure how it was done in the factory as I have heard a number of versions, however I "suspect" that the entire car was painted body color (sealer, primer and then color), then the fender tops and tail light panel were masked and shot. Thats how I did my Cuda (not an AAR, but AARish).
Of course the other way is to paint the black and then mask it off and shoot the body color but to me that seems more difficult especially if you are going to shoot body color into the trunk and under the hood.
70chall440
Western Washington
I am not sure if you are asking something or making a statement.. The black is matte or satin so it would not get clear (possibly matte clear, but I am pretty sure the original cars did not have any clear on the car period, they were using a single stage paint for the body color which has the clear in it).
gtxno1
Freehold N J
I will be using base coat clear lets say I shoot the fender hit the whole fender with basecoat only clear the color paint black on top of the fender that has been base coated or no color at all for the blackout area?
70chall440
Western Washington
As I mentioned, I would paint everything body color and then come back and paint the black. Since you are going to have to scuff the areas to be painted black it doesn't really matter if you shoot clear over them (since you will be sanding/scuffing them). This should make it an easier job in that you only have to tape it up once.
I would have to agree with 70 chall440. Mostly because paint is more of a sealer,primer and any flat or low gloss by it'self don't.
gtxno1
Freehold N J
What paint on that upper cowl area is that organasol also the tail lamp panel
ctaarman
AARs had multiple coats of organosol on top of the body paint. crudely edged with a masking tape. Also sprayed on top of the hood pin backets inside the engine compartment along the fenders. ( Most painters screw that up).There is no flat black I know of that can duplicate the slight crinkle of organosol. I've heard zome folks trying some sand in flat paint but have no experience with that as I was able to find some NOS organosol a few years back.
