Cuda Hunter
SCORE!!
dived into some of the fun stuff first,still battling my air compressor, drawing to many amp still but managing for now. Like I said earlier going to peel it back and o boy, got back to solid metal and stated layering in back together, with coat the underlying metal with acid and nickel phosphate, then etching primer, then sanding down the areas to be welded as good as I could. With a little 2k primer it should look pretty original.How are you addressing the front of the rear wheeltubs for rot/rust?
of course the final pic of it completed file to largedived into some of the fun stuff first,still battling my air compressor, drawing to many amp still but managing for now. Like I said earlier going to peel it back and o boy, got back to solid metal and stated layering in back together, with coat the underlying metal with acid and nickel phosphate, then etching primer, then sanding down the areas to be welded as good as I could. With a little 2k primer it should look pretty original. View attachment 132466View attachment 132467View attachment 132468
thanks its just what needs to be done, a pain in the ass, but knowing it will last for a while.Now that is some impressive work. Following closely.
Very nice looking spot welds Don!oh well will try to take completed pic tomorrow. welded trunk braces and spare tire holder into trunk pan. with be climbing up into the depths of the trunk with a rattle can of etching primer just to get something on the View attachment 132473View attachment 132474View attachment 132475View attachment 132476View attachment 132477 metal up there, before pan goes in
