AAR resto
got the 4 corners in deck height is super close to flush I'd say flush on #1 and #7 maybe .010 below on #2 and # 8, gonna install all of them, before ring install, John has a straight edge he's gonna bring over later and see exactly what we have. rod clearance in between on the crank seems to be pretty tight, moves freely but doubt i could fit a feeler gauge inbetween. looks like plenty of rod clearance to the block at the bottom of the cylinders, so that should be good. Had an issue with one of the piston clips, kind of waffled one, got it in and looks like the rest but for the price of a clip its not worth the risk.
well rod to rod clearance specs at .0060 to .014.
ranging from
.000 to
.030 to
.007 to
.002
not sure what to do with that at the moment. It does turn over nicely but it Looks like will be calling CNC tomorrow to see what they wanna do. it is the crank journals, rods are consistent
piston deck height is nearly perfect.
haven't checked the vavle piston clearance yet, or plastigauge anything kinda useless until i get the journals taken care of.
Keep us posted on what CNC says/does for you. Because anything less than .006" rod clearance will likely cause very bad things to happen when normal operation temperature is reached and you've got too much labour and money in your AAR Cuda for that kind of headache! And the .030" will allow a lot of oil to leak out! Not good either! Glad you're checking everything!
well packed up the stroker kit and sent it back in waiting for the verdict to come in, been working on the Grand National for now. Going to have to go back to work again Monday to my regular job, lined up some metal framing to do on a few small jobs should keep me busy for a week. By then hope to hear some news from CNC Motorsports. Here's a few pics on the GM, descaled everything shot it with encapsu
lator and some SEM matte black and some light undercoating in the fenderwells
well got my stroker kit back, they looked at the rods and said some were in backwards, which caused the tightness, John was unaware that there a top and bottom on the rods. So they had an attitude right away, I was being cool with them and accepted my fault asked if the bearings needed replaced they say no, I talked to Clint on the phone, and asked very nice to please check the .030 clearance between the rods on 3-4 crank journal, He said they will check everything. Well got it back late last week, I used green painters tape to seal each layered box that protected the crank, they never opened the box. CNC motorsports is not impressing me at all. left them a very nice email today with videos of the unopened box and installed the 3-4 bank on the crank to show the .30 way too big clearance. Dead in the water, again. Expecting a phone call tomorrow I hope they come to there senses, I would hate have to go to south Dakota just to throw this crank thru there front window.
That sucks! Yes, on Mopars the rods have a bigger chamfer on one side that faces away from the other rod on the journal. Measure the widths of all four rod journals. They should be within a few thousands of a inch from each other. If the 3-4 rod is noticeably wider, CNC has a problem!!
we were aware of that, the rod bearings are marked upper and lower which we were not. Thats where our mistake was, that caused the clearance to be tight on two of them. one was right the bearing we got lucking and installed correctly and 3 and 4 has a .030 clearance. I made this aware when I sent the crank and rods back to south dakota for $286, and they did not check the crank at all didn't even open the box it was taped shut with green masking tape, it was never removed. And they requested that I send it too. I usually have the rotating assembly completed then assemble the rest.
ya pretty much, I was straight forward and courteous in the email, but some of my video comments on showing the issues of not even opening the box, installing the 3/4 bearings and rods on the journals, etc were lets say colorful. They are a few hours behind so will wait till noon for a call, if not I won't be so nice, this is ridiculous. basically just need a new crank balanced for the bob weight. Glad I bought it with a credit card, so I can dispute it if they get shitty about it.
Well they assure me that .030 clearance between the rods are fine, they say up in the .040's is acceptable. :BangHead:
I was concerned about holding oil pressure with that much of a gap. Would suck to completely assemble this and get 10lbs of pressure with a high volume pump.
Been following this. In short my school of thought and has I was taught and learned. To Blueprint ( That is really nothing fancy just a common practice.) an engine is to bring it to factory spec. That give it's longevity. I tighter tolerance gives better oil pressure for longer wear.
Now if the engine is used to do a 1/4 mile at a time. You want a looser tolerance. Ergo, .040" Less friction gobs oil flow for a short time and x number of passes. Then a rebuild.
Is the latter their intention and not durability. Or did they just screw up! Go back and read the fine print. I kind of agree with their specs. But to what limit? . Just my 2¢ Oh By the way I learned to peen everything I toque or loosen.
My views are similar, car will be a snotty street car, Maybe a run at the track once or twice just because. Consulting a few other people before this thing goes back together.
Well posted this issue on FBBO, most stated side clearance like that won't effect anything especially with the newer aftermarket stuff, Just alot of $$$ invested and kinda scared just to call it good with out some professional insite, especially when just one journal is that far off. Just being cautious. well back at it. thanks Challenger RTA
.030" is excessive. I know folks used to run stock big block Chevy rods on Mopar cranks offset ground for more stroke and had lots of excessive side clearance (Chevy Rods are thinner).
Personally as an ex-crankshaft grinder, I'd be pissed because it's a FUBAR situation no matter how you look at it! Sure, it will probably be fine, but I'd want another crankshaft!
One thought to minimize the clearance is to measure all the rods widths and use two of the "thicker" ones. Might reduce it to .028.
I agree that's whats been keeping me on the fence about assembling this. Thanks for the rod thickness go to, Ill be measuring them. I go all out on a project and when I received something that was an obvious mistake and told aaaay it'll be ok, it sucks.
