Hello!
Currently, we are replacing and repairing the body panel.
So the question is, how do you glue the body panels other than the frame?
I scraped the panel adhesive surface to roughen the skin, and I was thinking of bonding with 3M panel bond and spot welding.
However, in 100V spot welding, if the panel bond was sandwiched, it could not be bonded (is the voltage insufficient?)
Is it only necessary to use a panel bond for panels other than the frame where force is not applied?
Or is it better to do point welding instead of using panel bonds?
Also, it would be helpful if you could tell us about measures against rust caused by heat during point welding (heat-resistant rust preventive paint, etc.).
thank you for reading it until the very end!
