Adaptor for Custom Radiator and original transmission line
wiging19
North of Seattle
I have a high performance Entropy radiator which has female plug holes. The original Transmission line needs a male feed. What adaptor has anyone use to make the connection between the two?
What size, there's adapters for anything you can imagine.
Something like this?
brass fittings (male-to-male) screw into the bottom tank, and then the hydraulic cooling lines are screwed to the other end of the fitting. A plumbing supply store should have the fitting you need, if you can figure out the thread sizes.
Thanks for the suggestion on where to go. I was thinking of a speed shot where I got adaptors for my fuel line.
Ace Hardware! Ace is the place! Plus they're actually helpful! 9 times out of 10, I'm heading to the screw/bolt/fitting aisle for something car related.
