American Autowire Install tips/questions
ShiftedGarage
NC
Long time lurker first time poster. Just finished a complete rewire on my 74 cuda with the american autowire harness. I recorded it all and posted a video so hopefully that helps some people out or gives them the confidence to do this project yourself. Heres a link to it
Key things to know if you are going to do this yourself, if anyone else has any tips feel free to chime in.
- 1 wire alternator is what this kit uses
- Crimpers that american autowire sells are worth every penny for the project
- Ammeter delete. Kit does not use a ammeter at all so a voltmeter conversion is required if you want something in your dash if you are using factory style guages. There are 2 models that are known to work/fit in the cluster Bosch FST7985 or SunPro 7985. Both these styles have the needle base at the top of the guage which is needed to fit in cluster. Gauge will need to be fully removed from the pod it comes in and just the actual gauge itself will be used. I didnt have to modify the gauge cluster at all just some tweaks to the new voltmeter for proper fitment.
- Nows the time to do the clock - quartz conversion while you have the whole dash out of the car there are several write ups on this already so i wont beat a dead horse
- Dont throw out your old harness, some connectors need to be re-used (turn signal, ignition, side marker turn signal, and possibly wiper switch) save it until you are complete with the install.
- Pay alot of attention to the directions, seems like an obvious statement but when matching old harness to new harness parts really pay attention to color and connector positioning (re-pinning a mistake sucks) they lay out old harness color to new harness colors for continuity.
** IF you happen to have PN#3488773 (2-speed wiper switch) that only has 5 prongs on it while every other switch out there and the instructions only have pictures for the ones that have 6.. I’ve done the homework for you. Keep old harness connection as the supplied one wont fit, these are the connections
A - Brown
B - Pink on original harness (Ignition On Power)
F2 Green
H - Red
P - Blue
With the new harness the pink becomes white and everything else remains the same. The brown with white is for power wiper washer fluid. I de-pinned my old connector, cut the connectors off the new harness and pinned the new wires into the old connector. My old connector still had the brown with white provision and wire so feel free to pin it just so there isnt any loose wire. With this fully tested and everything works as advertised.
- Having the service manuals handy is a nice help to have and to double check yourself on somethings like adding in the side marker turn signals.
- If using aftermarked ignition (I used MSD 6AL with a magnetic pickup) they have instructions for certain types but they describe also what wires can be used as a power source for your ignition. Once identified use the instructions for your ignition system to finish that install.
Hope this helps some of ya’ll again video helps cover how everything went/ installs but this is a good synopsis.
Overall not a bad install, have patience it takes time and planning on how you want to run, crimp, mount stuff. This was my first time doing any major wiring took me about a 6-7 days to do being very tedious and double checking instructions, forums, and manuals
I was entertaining just a simple engine bay kit, using the existing fuse box for now. Is this do-able?
A - Brown
F2 Green
H - Red
P - Blue
Thanks for the post i bet it will help a ton when i do the same on my 70 challenger. I have the same wiring kit. I checked and found the sunpro gauge on Amazon.
where did you find the quartz clock and do you have the model number? is it R-3035?
also, beside the crimpers you suggest, any other tools you recommend? a test light or power circuit probe?
thanks!!
thanks!!
I installed the aaw kit into my 70 duster. At first it was absolutely overwhelming. Million miles of wire and connectors was staring me in the face. I only used a volt/ohm meter. In a couple of cases I had to use butt slices but had those on hand. I also bought several rolls of wire wrap to make the wires tidy. Ran into a few issues but worked through them. Take your time and it will work well.
This thread has a good heading to direct other in the right direction. I'll post a number of quotes that relate to it.
Looking for some wiring help. Trying to wire into my American Autowire connector. The AA diagram looks like it has the old colors for a stock turnkey switch. Aftermarket Turnsignal has the following colors on the connector:
WHITE (At the pointed End)
GREEN
MUSTARD/Blk Stripe
RED
BLUE
Lt Green
Yellow
Green/White Stripe
I cannot find a pin out anywhere for these colors....anyone got one?
I'm not familiar with that wiring package. As far as a pin out there is none. I made one for the turn signal switch. It looks like what you showed. Is there a makeup plug or adaptor they sent you? If there keyed(made the same) the same it more than likely it should work. Anyhow maybe this will help.View attachment 135218
So you needed to cut the plug from the switch? This is what it should be on the new turn signal switch to the AAW wiring colors. That your showing me. A better picture of figure E would help.
MOPAR turn signal Switch colors---------- After market Switch colors-------------AAW wire colors
Stop lamps-------------White -----------------White------------------------------------White
L F turn signal --------LT Green--------------GREEN ----------------------------------Light blue
R F turn signal -------Tan---------------------Yellow/ Blk Stripe ------------------Dark Blue
Emg Flasher ----------Pink-------------------RED --------------------------------------Brown
Turn signal Flasher--Red---------------------BLUE ------------------------------------Purple
L R turn signal-------Dark Green----------- Lt Green --------------------------------Yellow
R R turn signal-------Brown-----------------Yellow -----------------------------------Dark Green
Horn relay------------Black-------------------Grn/w-----------------------------------Black
AAW wiring. So you needed to cut the plug from the switch? This is what the colors would be on a new turn signal switch. The AAW wiring colors. Figure E. The Mopar wiring colors. My opinion: If you have the the car side of the turn signal sw plug. I would cut it with enough wire to remove the insulation. Then soldier the AAW wires to the plug wires and have shrink tube on before soldiering. Or get one. That way you retain ease of replacement and or trouble shooting. They are low current.
R F turn signal -------Tan---------------------Orange/Blk Stripe ------------------Dark Blue
L R turn signal-------Dark Green----------- Lt Blue--------------------------------Yellow
Horn relay------------Black-------------------Grn-w-----------------------------------Black
AAW wiring. So you needed to cut the plug from the switch? This is what the colors would be on a new turn signal switch. The AAW wiring colors. Figure F. The Mopar wiring colors. My opinion: If you have the the car side of the turn signal sw plug. I would cut it with enough wire to remove the insulation. Then soldier the AAW wires to the plug wires and have shrink tube on before soldiering. Or get one. That way you retain ease of replacement and or trouble shooting. They are low current.
BEAWARE After market switch colors may vary. Pay no attention to the color chart in the picture. I have no idea what it is referring to.
Ok so I wired it like above and my right and lefts were crossed up. Flashers were fine. So here is the final arrangement which I will share with AAW peeps as they did get back to me:
Aftermarket Switch PigtailAAW Colors
Stop LampsWhiteWhite
LF Turn SignalGreenDark Blue
RF TurnsignalYellow/Blk StripeLight Blue
Emg FlasherRedBrown
Turn Signal FlasherBluePurple
LR Turn SignalLt GreenDark Green
RR Turn SignalYellowYellow
I will solder everything this weekend, heat shrink it, and move on to ignition wiring!
I finally got the courage to start the rewiring project and i removed my dash to begin the install of my AAW kit. I then I discovered that my car is an AC car and the instructions state
"This kit DOES NOT provided any wiring for factory combination Air Conditioning (A/C) and heater systems. However, this kit will support the use of and does contain all of the necessary wiring for factory heater-only systems. It also supplies power for any aftermarket A/C and/or heater systems."
I'm also reaching out to AAW but do you guys think this means i would just have to reuse my current AC wiring and it would work or am i just reading too much into it?
Thanks.
Thanks.
When I wired my Duster the firewall opening for the connector block was used for the new block that comes with the kit. When installed the stock under dash ac system hit the new block. Not sure about E bodies. OE wiring will not work with the new kit, with few exceptions. You may be able to wire the ac but the kit will not help.
AC control wiring.
Dash side wiring.
Engine bay side.
Other examples
The more I see about these general American Autowire kits and the Painless wiring kits, the more I think, it might be easier to start with fresh factory repro wiring harnesses from M&H (Year One) and then add/subtract wiring from that for any custom applications.
I think you get it. The trick is to remove or minimize the high current loads. Then maintain the connections.
Talk to Evans Wiring. All they do is Mopar wiring harnesses. Family owned business.
Evans Wiring - Home
I had bought, but never used, a 440 engine harness from Evans Wiring and it was top notch. I bought the engine harness from them before the internet and I forgot all about them. I wish I would have contacted them prior to buying the Painless harness that I bought.
If done right the AAW or Painless harnesses work great but you have to use some of your original harness/plugs and you must use a factory service manual to decipher circuits and points of connection between the aftermarket harness and the factory connection points. Take your time and make sure you have good grounds.
New to the forum. Long time Mopar owner, recently acquired a decent driver quality 73 BH23 to go along with the 3 A bodies in the fleet. According to SN, originally a 318 car, presently has a 440/ 727. No fender tag, no build sheet.
I have purchased an AAW wiring kit and a Classic Ind Elite gauge set to replace the complete 50+ year old wiring. Will be switching from ammeter to volt meter. Have just started removing and labeling the existing harness.
Any advise from those of you who have done a major rewire. Particularly regarding suggested alternator, voltage regulator upgrades. Thanks in advance for any advise.
There are a few members here that have done it. I hope I was a help to them. They know better because they have first hand experience. Below is a link about one of them. Start a new thread on you install. It makes it easer to follow. Also if you would go to welcome wagon and post.
