MOPAR turn signal Switch colors---------- After market Switch colors-------------AAW wire colors
Stop lamps-------------White -----------------White------------------------------------White
L F turn signal --------LT Green--------------GREEN ----------------------------------Light blue
R F turn signal -------Tan---------------------Orange/Blk Stripe ------------------Dark Blue
Emg Flasher ----------Pink-------------------RED --------------------------------------Brown
Turn signal Flasher--Red---------------------BLUE ------------------------------------Purple
L R turn signal-------Dark Green----------- Lt Blue--------------------------------Yellow
R R turn signal-------Brown-----------------Yellow -----------------------------------Dark Green
Horn relay------------Black-------------------Grn-w-----------------------------------Black
AAW wiring. So you needed to cut the plug from the switch? This is what the colors would be on a new turn signal switch. The AAW wiring colors. Figure F. The Mopar wiring colors. My opinion: If you have the the car side of the turn signal sw plug. I would cut it with enough wire to remove the insulation. Then soldier the AAW wires to the plug wires and have shrink tube on before soldiering. Or get one. That way you retain ease of replacement and or trouble shooting. They are low current.
BEAWARE After market switch colors may vary. Pay no attention to the color chart in the picture. I have no idea what it is referring to.
