Antenna wire routing
challboy728
Ponchatoula, LA
Not sure if this should go in electrical or interior - but - does anyone have routing description or routing pics for the antenna wire on a 1970 Challenger T/A? My antenna wire has a plug on it like it goes thru some sheet metal, has a clip on it and has tape on it. I took it out some time ago, and don't remember the routing (note to self "Take pictures next time!!!!").
Thank you!!
floyd
Here’s the factory drawing:
https://www.e-bodies.org/Resources/Engineering_Illustrations/TA_AAR_Antenna_wire.pdf
There are two cables used for TA/AARs. There is a long extension cable that connects to the radio and then routes back towards the RH 1/4 panel. From that point back, the standard fender mount cable assembly is used. The chrome bezel used for the rear antenna mount is different than the e-body fender mount bezel (although I believe it is the same one used by other body styles).
