Anyone use ProMax Parts?
VillaTA
Cincinnati
Just wondering if anyone has used the promax stuff. Wondering what I can do to make my six pack mixture easy enough for a non mechanic to manage
fasjac
Arkansas
I also use the base plate on the back carb. It’s good. Also, tried the fuel lines, s work fine. Nothing internal on the carbs though.
Mopar Mitch
NW Chicago Suburbs
I use the ProMax sixpack parts. Their base plate is the way Holley should've made it (easily adjustable rear carb)! My overall setup runs great!
VillaTA
Cincinnati
So, the base plate won’t cause the air cleaner to be too tight on the hood?
fasjac
Arkansas
No, it replaces the original Holley throttle base plate with about a 45 degree angle mixture screws. So you don’t have to remove the rear outbound carb to tune. Same height as Holley.
6PKRTSE
I never had an issue without Promax parts. I just adjust accordingly. Once adjust
ed, put the front carb on the rear and then adjust the other front carb again.
VillaTA
Cincinnati
if I switch to pro max fuel lines, do I have to totally retune the carbs?
fasjac
Arkansas
I didn’t when I installed them. My only issue was, they didn’t lay to my liking. Too close to the front diaphragm link rod. No matter how I adjusted them. Ran fine, no leaks etc.
I went back to original. Got a set up for 125 if you want.
VillaTA
Cincinnati
I was worried about fitment there as well. I think I’ll stay with the original for now.
