cstmhmmr
Installed brand new one with Power booster, made sure everyhting is lube with lithium
This what neighbor ask. So he is only here part time but promised to bring power bleeder down an help me search for problem.Do a complete brake bleed with fresh fluid and a clean, clear container. This will let you see the strength of the flow from each wheel and any debris in the system.
I agree ,Year One has the proper harness's that are plug and play! They have 30% discounts all the time, They even have one this weekend and the promo code is WAVE. I believe MEGA PART'S has them also.I would probably buy it if I had 10K right now !!
You will get through this , just have to work through the problems.
Y the way I would not replae the harness with Painless , painless is just a name you can buy proper harnesses that will just plug in , it is a LOT less work
yes have done all this, awaiting a power bleedr=er from a friend to draw fluid through all lines an see what I come up with. Thanks for your insight. Been suggested the cam may not be letting me draw adequate vacuum.
