Car won't turn off anymore
mopar70
Canada B.C
1970 Challenger 383 Petronix ignitor 2 inside stock Mopar distributor. Car wouldn't charge battery but would turn off when key was turned back. I replaced the alternator and now the car charges the battery but won't turn off when you turn the key back. Am I wiring something wrong?
challenger6pak
Do you have a stock alternator or a one wire alternator? Is everything stock other than the Pertronix? I'm trying to narrow down possibilitys.
AUSTA
PERTH WA
Could be leakage through the regulator see attachment
mopar70
Canada B.C
It's a stock replacement alternator. I don't have the ballast resistor hooked up never had got the car as is. But there are 2 plugs there for ballast resistor. Voltage regulator is plugged in. Then there's one blue wire that's on + coil. Then the blue wire labeled distributor is going to the electric choke on carb. My tach wires not hooked up I don't know where it is inside the car. Hasn't ran properly in a long time.
AUSTA
PERTH WA
Try pulling the green wire off the alternator when the key is off but engine is still running if the engine stops you may be getting a back feed from the alternator & needs a blocking diode as above.
If the engine doesn't stop then your problem could be else where
