Challenger Camber adjustment
BoomerSoonerVA
I finished putting the front end of my car back together. I notice there is to much positive camber on passenger side how do you adjust this?
What size tires and wheels? Is the engine installed ? Are the front control arms stock or replacement ? Has the correct ride height been adjusted ?
Front wheels are p185/70/r14 and yes the engine is installed. Stock control arms and height is correct. Didn't have this issue when I took it apart
camber (2).jpgCamber is adjusted with the eccentric bolts on the upper control arms. You would need to rotate the bolts so that they offset is to the inside
http://www.qa1.net/suspension/stree...justers/mopar-eccentric-camber-bolt-adjusters
