Convertible Boot Clip Question
Surfcuda
Palmdale Ca
To all Convertible owners Im asking for some help. I ordered a Boot Cover from Legendary. The Clips on the new boot will not attach onto the molding, way to tight and will not flex over the molding. Seems almost every reproduction part I buy will not fit or has to be modified to fit. Has anyone else experienced this issue with the repo clips? Looking for a remedy to correct the issue or a source to get clips that actually fit? Any help would be appreciated.🌴
I too have found it nearly impossible to get the new style clips that come on the reproduced boots to clip on like the original clips. I also recently bought a repro Legendary boot. I've considered using some heat from a hair dryer but it has gone to the bottom of the list of things I have to do on my cars. I have a bunch of new clips like the originals (with the metal spring on back) and considered taking the new boot to an upholstery shop to have the original clips replace the plastic ones but again, not a rush item. Please keep us informed if you find an easy solution that works. In my photo, original clip on left and an exact repro on right - the clips in the Legendary cover does not have the metal spring and is thicker.
Terry W.
I have some original clips as well. I wanted to see if Legendary would make me a boot cover using my original clips. Like Terry - it is low on the list of things I need to do to the car at the moment.
