Door panel fitment issue
Marlon L
Manitoba
Hello, I sure hope someone can help with this. I am putting new door panels on my 73 Challenger but they are about a 1/4 inch too narrow. If I hang them and put the screws in the back, the front screw holes are close to a 1/4" short of lining up. I tried heating the ends with a heat gun and it did get it closer but I'm afraid of distorting the plastic. Has anyone encountered this and how did you rectify it?
I will try to get a photo today.
Thank you.
I ran into an issue with the reproduction inner door panels. The originals had a beveled edge on the inner portion where the plastic meets the metal door shell. The repros have a hard edge which prevents the panel from fitting snug.
I used a dremel with a cutoff wheel to bevel the edges and they fit well afterwards. Obviously, you need to be careful with the cutting wheel, but it’s relatively straightforward.
I would contact the vendor and let them know of the problem. They might send you another set or at lest compensate for you trouble.
I would do as you have done and maybe elongate the holes.
Having worked in the injection and blow mold process. I would have to say they were not cooled before the were removed. Mold temperature to hot.
If you still have your originals, do a side by side comparison. You’ll see what the issue is. This seems like a tooling issue to me.
Another difference I found between my originals and the reproduction was the lack of these small contour notches. I’m only familiar with 70-71 Challengers but all my originals have these notches.
I got them from Roseville about 5 years ago. I can’t recall who is making them now but they are the “good” ones that I think Metro made originally, not the Palco ones.
Overall, they are very nice reproductions but, in my experience, reproductions are never a 100 percent match.
I got mine from National Moparts in Ontario Canada. I'm not sure who the manufacturer was though, I would have to look into it. I bought them 2 years ago and just putting them on now.
Hi Floyd, thanks again for the tip.... That worked😁
Should reach out to the vendors and let them know the issue and solution so they can get it right. I know companies like 440 Source, Hughes Engines and Mancini read lots of Mopar forums to see how people like their products and what they need to change or improve.
Floyd did you cut these slots in your new panels
Yes I did. Not sure it added anything but was looking to match the original as close as possible.
Mine has a space by the front of the door ..If I screw it tight it would pull through the panel maybe the slots would let it flex a little
