I would also add a few thoughts when working on mine.
Most of the rebuild kits come with a new a new "Steering Shaft to Shoe Pin". I made the mistake of removing the original hardened and ground pin fro the inner shaft (which was really hard to do). The new dowel was lesser quality and undersized to the hole in the shaft. Thinking that it would cause slop I went back to the original. After talking with some people and inspecting what I had, there was really no wear on the parts, and in the end all that was needed was to be re-greased and top seal installed.
Also the new covers are made out of what appears to be inferior metal that doesn't stay clamped as nice as the originals, may want to try and reuse your original if you can.
