Drip edge moulding
money pit
How do you remove the moulding on the drip edge? I'm trying to remove it before I get the car painted. I wasn't sure if I need to remove the rubber weather seal, if it's secured with screws, or pressed on. Thanks.
Pull the rubber out and you’ll see a row of little screws .
Work it off with a tool. The stainless outer part is glued with a thin weather strip. If you pull it, it will kink and bend. I use a popsicle stick when it doesn't pull loose easily.
Thanks everyone. I tried to pry on the moulding a little but it didn't budge. I thought there were screws. Thanks again.
Here are some pics of my drip edge molding I have off my car right now. Rod
