Electrical gremlin 1973 cuda 340 auto
Ralph
Went out to the car show and the next day changed the oil and the car was dead.
The dome light goes on, but when you turn the key it dims about 80%. No noise from the starter. No headlights etc
-So i had another starter and changed it out and nothing.
-Fusible link looks good and it was replaced 3 years ago - power on both sides.
-Changed the neutral safety switch.
-All engine side wiring was installed new 3 years ago along with all steering column wiring.
I was thinking to change out the ignition switch next and buy a new fusible link ( i assume there is only one at the starter relay.
Any thoughts
704406
Shawnigan Lake B C Canada
Let's start with some basics. Have you checked the battery voltage? Battery connections clean? The ground cable on the engine block? Do the headlights come on bright? The light going dim while key in crank position is a good indicator of low voltage. You can jump the starter solenoid by the battery to see if the starter cranks without using the ignition switch or wiring harness.
Let us know what you find after checking the basics.
Ken
AUSTA
PERTH WA
Just make sure it is in park.
Put a 12 volt globe across the 2 trigger wires on the relay to see if it comes on when you turn the key.
Muffler124
What is the bat voltage after key on? And when engaging starter?
AUSTA
PERTH WA
around 11.5 to 12.5 if the starter engages then 9.5 to 11 while cranking
Ralph
OK, went back to the basics.
Bad battery and loose wire under dash.
Changed out T handle which was worn and neutral safety switch and it started right up.
Thanks to all.
moparlee
Mid Michigan
Good deal, glad you got her going again. What was the loose wire under the dash? BTW, very nice Cuda!
Ralph
Patch to a burnt wire leading up to the steering column.
Need to change the wiring someday.
Thanks for all your help
Ralph
Cudafor36
Sylvania Ohio
Similar but not. All new year one wire harness' all of them. 73 Cuda. Dome light stays on when the housing for it is screwed in. When not attached to the roof it won't turn on with the dimmer switch just when I open the doors. Map light won't work with doors closed but can come on when they are open. This is all after my timer is timing and even when finished.
Help please. I traced all the wires and found nothing to be the culprit.
moparker
Nearly identical to my first car. I would love to get another one.
