1973
- Joined
- May 11, 2012
- Messages
- 59
- Reaction score
- 18
Hope this is ok, but I was not sure if I posted anything to my last post "Small to Big" if it would be seen, so I started a new post.
I have a 76-77 Cordoba with a big block in it (400 right?) and I am going to swap this into my 1973 Cuda. (318)
Wondering if all the parts will just bolt right in - or what will i need to change?
oil pan?
engine mounts- frame stands (do i transfer them over to the Cuda from the Cordoba or??)
trans should be the 727 correct? will the trans mount swap over?
i will probably need a new drive shaft, but i think the cuda already has the 8 3/4 as it has bolts for the center section on the trans side.
some one said I should look for a bracket on the trans so my stock slap stick shifter will work- can this just be moved over to the cordoba trans? (MD2540)
thank yo for the help, any tips would be appreciated
oil pan?
