Front sway bar bushing collar
71RT383
CT
Hi, I can't find one of the front sway bar bushing collars (holds the sway bar to the k frame) . For my 1971 RT challenger.
Also trying to locate a small "L" bracket that attaches to the front lower right of the headlight panel, on the right fender. ( I only have a pictures of the left/driver's side). Not sure if it helps support the grille?
CIMG5304.jpgCIMG5305.jpgCIMG5312.jpg Thank you.
moparlee
Mid Michigan
My 71 was also missing one of those L brkts. I just made one out of bent sheet metal. It does support the grill and its hidden enough that you can hardly see it.
You might check with PST for the sway bar brkt or someone here on the site probably has one.
71RT383
CT
Thank you for the info. Since the bracket is hidden , and the grille is lightweight, I will try to make one up. As for the sway bar bracket I'll try to locate one and if no luck then I'll try PST. Thanks again Moparlee. Stay well.
