shadango
- Joined
- Jan 29, 2009
- Messages
- 108
- Reaction score
- 6
I have an angry cam in my 318 and have always struggled to get it tuned good for idle --- edelbrock 600 carb -recently tore it all down and cleaned ot all etc and have been tinkering to reset stuff....have the idle as good as it will ever be, but in my tinkering today I had a rude surprise....I can run hard up to 5k hard in first then manually shift to second but when I approach 5k in 2nd, the engine starts to fall flat around 4k.....bad.....cant tell if its gas or spark to be honest....its not "breaking up" like a rev limter/spark would do so I am thinking gas.....
I also saw today on my under hood fuel pressure gauge that the fuel pressure is jumping sporadically at idle or even revving up between 6 down to 4.5 lbs -- real jerky like. ....so I am putting the two issues together and assuming the pump is on its way out after some 12 years of crusies and fun runs....I do have a fuel pressure regulator plumbed in as well fwiw, set at 6 psi.
So anyways.....went to the old interweb/Summit....figured I would pick up a new pump.
As I recall, the block in my 72 Cuda is a 76 318......back some 10 years ago when I was wrenching on it I used a 76 Duster 318 to order my last fuel pump...I found my old notes and had numbers written down.....a #60514 airtex which happens to be the same number as a carter pump... and also 6866, which is listed for a 72 Cuda with 318. I circled (and bought) the 60514.......
Was gonna order the same thing this time on summit but then saw in an ad there that summit also offered a "muscle car fuel pump for small block chrysler"...part 6866...... But oddly the 6866 says it does NOT fit the 76 duster 318 and the 60514 says it fits the 76 but NOT the 72 318.... I had made the same discovery back then I thought the LA motors were all the same throughout the years? I was lured in by the "muscle car pump" since it claims to have premium features for the same price .....heavy duty diaphargm, antifloat valve......I guess the 60514 has been fine all these years til now....but I am curious......the images of the two pumps look the same, same ins and outs,etc etc....wth is the difference between the 72 and 76 blocks as far as fuel pumps????
