GAINS FROM RAISED PORTING INTAKE AND ALUMINUM HEADS
TIMINATOR
Avondale,AZ.
I have a set of aluminum heads that I will port and wondering if raising the top and widening the port to the big gasket size will gain much.
Heads now only flow around 280 and I own two sets, a Chinese set and performer RPMs too. There is enough meat in two of the intakes I have to do this. Just wonder if anyone has done this.
TIMINATOR
I pay close attention to what you say. I think you are one of the few here in a class of you own. Very knowledgeable. You know what you are doing. Now I wonder if this is a test? Maybe your just seeking a first hand experience. No offence meant here.
This is why our mopars where built.
Not a test.
Ported stock 440 heads gain about 28-34 cfm with this max wedge porting. You don't even need to widen them to get some gain.
But stock heads have a big hook in them that aftermarket heads dont. But since I have performer rpm and raised runner speedmaster heads I was wondering if anyone has flow tested with raising the inlets. If no one has got this info I guess it's back on my flowbench and map the port before doing any work.
If no definitive answers I guess I will get on it in my spare time. Which I don't have much....
TIMINATOR
P.S. ya gotta raise the intake manifold too. Some can be raised more than others. "In the day" I raised the intake first a safe amount, then raised the heads the same amount.
Knowing enough to be stupid. I was thinking the maybe the intake could be machined to lower it to match the heads. Same as when the block is decked the intake side needs to be machined to some extent. Just wasn't sure how they were matching up originally. It's all the opposite of what I was thinking. Thanks
Maybe I'm lazy, but if I wanted Max Wedge flow, I'd just buy a pair of Indy or 270 TrickFlow heads and their intake and call it a day. Seems like a lot of work for something that will probably flow more than the "stock" head, but less than a "max wedge" type head. You could sale the two sets you have to help offset the cost of Indy or 270 Trick flow Heads.
I have 3 motors and 3 sets of heads. And a flow bench. And a dedicated porting room.
Factory iron heads have a big hump in the floor and raising the top of the port gives a straighter shot to the bowl with a good flow gain
Edelbock and 440 source (I have a pair of each) minimize the hump and the speedmaster (other set) raises the floor around 5/8" and extends the port higher so to minimize the hump completely.
Time to see what they all flow.
I will apparently use the lesser heads on the 2 498s and speedmaster raised ones on the 512.
I need to either get 2 A bodies or a shortbed truck. The 72 Challenger gets the 512.
All of the heads are stock as of now. I will post some stock numbers. 440 source, e brock and speedmaster advertise almost identical numbers. I can't see that the raised ports only flow the same as stock location ports. The bench dont lie. We will see and I will post.
TIMINATOR
Oh, this should be interesting! My understanding of the 440 Stealth head is they were just trying to recreate the stock "906"/"915" head in aluminum. If I had to guess, I'd say raising the top of the port would be good for 15-20% flow gain at the higher lifts. Will be interesting to see your results! 👍
Which Edelbrock heads? E-Street?
Performer RPM.
Those and the 440 source came In a package deal. The Speedmasters look much better by eye. I don't think the 440 source and perf rpm will flow much better than pocket ported 906s. We will see...
TIMINATOR
I have experimented with porting a LOT over the years but I don't have a flow bench , just time slips !
the motors I build Always run faster than they should ...
Anyway you will see some gain raising the ports for sure ... my $.02
Where I have made serious gains tho & messed with people on flow benches is concentrating on swirl , using a venturi to increase air speed & shaping intake & exhaust guides into a wing shape with a long side & short side like a wing then twisting the flow so it hit the back of the valve around 50* resulting in no loss of flow @ .100 lift & no stall in the port to .750 lift .
I have also seriously raised the transition from the carb base on the intake into the ports making a heart shape , wider with a smooth blend at the top & narrower at the bottom .
O typically run a 1" or 2" spacer from 4 hole to open and make the transition radius into the port start up inside the spacer. The 4 hole to open cnc spacers work well on most everything that I have tried. A big mistake many make is running too large of an intake. The air is accelerated in the carb, then slows in the intake and has to reaccelerate in the port. Jetboat guys usually make that mistake, as well as the dragracers. It's that kind of stuff that happens in the real world that the flowbench doesn't show. My 572" BBC jetboat motor with CNC'd Brodies and 274 @ .050 roller with an 1150 Dominator preferred a 4150 dart intake with a 4500 to 4150 adaptor over a Dominator flanged intake.
That was +58 HP at 5800 rpm where the pump held it to. You can't believe how many folks called me cheap and told me how much better it would run with the "proper" intake.
I never argued?, just agreed with everyone that I really was cheap and stupid!
The area of the 4 throttle bores together was slightly smaller than the throat of the intake and adaptor.... Sometimes your eyes lie, that's where experience, and a flowbench are helpful.
TIMINATOR
Looking at a set of Speedmaster 200cc as cast SBChebbie heads, the intake port at the flange are almost the same size as the Speedmaster 440 mopar ports! According to their published specs, they both flow about the same! But the chebbies have a 2.02 valve and the mopars a 2.200 valve. That leads me to believe the restriction is the initial 2" or so of the mopars port in from the flange.
The 440 source heads port is quite similar too, but the divider is thicker on both aftermarket brands mopar heads restricting flow there. I will start my mods in the first few inches of port, then raise the port to the max wedge size, as my past port work on iron factory heads shows that raising the stock port increases the flow even with no other port mods. I first raise the intake manifold port as much as practical, then match the head and gaskets or use max wedge gaskets. I also weld the intake manifold port tops allowing more grinding on aftermarket manifolds, even though they have more meat on top than factory intakes. The factory heads can have the port tops raised as there is plenty of meat up there.
Most aftermarket manifolds have plenty of meat on the ports top to get noticeable gains. Why everyone's aluminum heads don't have max wedge intake port sizes, I have no clue! It just doesn't make any sense!
When time permits, I will get on the flowbench and post more, but now you all have something to consider!
TIMINATOR
I'm pretty sure that most after market heads are not max wedge size because realistically , most street driven Mopars never see over 4000 to 4500 rpms and the stock factory port size works fine for that! Obviously you are looking for the upper 95% performance which is cool, but for most people it's just not needed! The max wedge engines are definitely under appreciated because of the 426 Hemi race engine.
I'm still curious what your results are! Besides the thick web between the intake ports, the 440 Source heads look to have a lot of material in every direction compared to the Edelbrock heads. That's just going off what I can see visually from the ones. I have in the "Mopar Barn"!
You probably concur with me that Chrysler should have made the 383 and 400 into 426 and 444 (3.75 stroke) engines and the 413, 426 and 440 into 468, 482 and 505 (4.25 stroke) engines from the factory! Chrysler blessed us with tall blocks and long rods, but threw in heavy ass pistons that fortunately leeds to nice stroker combos with lighter pistons and more cubic inches! 😀
Even a near stock is under ported compared to chebbie and Fords. Although they could have made them bigger, without good heads all you have is a truck engine.
IMHO 440 source screwed up bigtime by not putting better ports in their heads.
I'm almost done with my home remodeling project, so I'll be in my mancave soon and report on head flows.
P.S. Edelbrock heads are a waste of time and money except for the Victor heads.
I have 440 source, performer rpm and speedmaster heads as cast. We will see...
TIMINATOR
P.S. the only reason 440s run anywhere near Ford and chebbie is their long rods.
I won't build anything other than a mild flat tappet 440 without 7.100 rods. They promote better cylinder filling and allow a much lighter piston. I would like to build a stock stroke 440 sometime with 7.350 rods and speedmaster heads....
I agree , with most of that .
RPM heads ported gained 3 hp over 452 heads ported , total waste of time .
Long rod engines rule IMO
The smaller 440 ports do increase velocity through the port & I have created awesome swirl with them . ford heads are too big / lazy except in very high rpm builds
Keep it up. I like this thread. 👂 :popcorn: Where's the ball stud hemi block in this. I understand for the most part it's a dream.
For the ĺifè of me I don't see going thru the trouble of making aluminum heads and not improving them over what you copied that was designed over 50 years ago. Just sayin'..
Why not copy the Max Wedge port?
Then you could sell intakes too, and really make some power.
I have always seen gains on the bench from raising the intake port tops as much as possible, that gains area in the "pinch point" next to the pushrod, it's all solid up there, and intakes have enough meat to raise it up there too.
That also straightens the port, vertically minimizing the "hump."
Speedmaster raised the port and added metal to the face allowing a straighter shot to the valve, but didn't narrow the web between the ports. That did result in airflow gains but the port at the face is still the size of a small block chebbie. That's why the published flow numbers are very close for both heads, even with the 440s .180" larger intake valve.
If I can't get the flow I want, and I already know I can't, I will weld the manifold ports taller too. I have been doing that for years and make it look stock from the outside. No one has ever noticed.
TIMINATOR
Here are two other members that I think are experienced in this. They might inject their 2¢.
Hemi wins every time. Yes, someone can build a Wedge to out perform someone's Hemi. If budget is no limit the Hemi will eventually beat any Wedge or brand X engine. Which is why all Top Fuel cars are still Hemi's forever for decades. Even today they are still the same basic architecture as the original. I enjoy my Hemi. However, I still enjoy my Wedge engines also.
Back in the late 80's when I decided to mess with big blocks, Hemi's were just wayyy to expensive and difficult to find in the UK so I've sorta stuck with wedges. The 655 we recently re-built made well over 1200Hp N/A but I'm pretty sure the dyno is optimistic, the timing tickets will tell the tale :) . Long term plan is to run a 500hp fogger kit, after a 'box and axle change.
One thing I noticed when racing circle track years ago in a 70 Challenger, our pretty much stock 360 (camshaft and higher compression pistons were really the only modifications) would last all season and the Chevy guys with their high dollar 355s would last about three weeks!
I noticed on my set of 440 Stealth heads there is a lot of material cast into the intake runners. Their CNC heads flow pretty well.
I too wait to see your results @TIMINATOR. Should be interesting!
P.S. 99.5% of the time, muscle cars never see over 5000rpm on the street. You just going to fast at that point. 😁
For the most part, yes for normal streetcar folks. For me, no.
I have built and run numerous 9 and 10 second street cars and Harleys. This Challenger needs to run 9s un tubbed with relocated springs and drag radials, on the motor. Then it will run high 8s with one of my plate systems. Or if I can find a reasonably priced used 8-71 or larger blower, I will go that way.
My 68 Nova and 72 Chevelle (P/S, P/B, A/C) ran 9s in driving to the tracks in full street trim in the mid 1990s, the Challenger needs to be faster.
I now have retired and need something faster than I had been building for others in the last 30 years.
TIMINATOR
I noticed even in the Edelbrock and 440 Stealth heads, there is definitely some gains to be made in the bowl area. They are better than stock factory heads, but still could use some work. Of course you know not to touch the floor on either the exhaust or intake, because they need more radius than they have!
@TIMINATOR, what is your stroker block plains? Cross bolted mains, girdle, partial cylinder fill? I'm asking, because there was a reason the factory beefed up the 426 Hemi block.
Side note: I have a theory that hasn't been proved, but I think the reason the 400 block (too short for my taste) was beefed up in the main webbing was because of the plan of making the two ballstud Hemi engines one based off the 400 block and one off the raised block (426/440) that only saw a few test engines being built. The web area is really the only advantage the 400 block has over the 440 block. I just don't like the shorter connecting rod the 400 block requires and it sounds like you don't either!
Just throwing this out there, but I wonder if you'd be better off just getting a pair of Indy 440-1 heads which are aluminum Max Wedge heads? Of course that takes out all your fun machining! 😁
