Gear Ratio help???
mj73rallye
MN
Hoping to get some help with gear ratios....
I have a 73 Challenger Rallye. It is 340 4spd and I am trying to determine the gear ratio. From what I have seen there is a ton of options....curious if my package led to a "std" ratio or alike? I still have fender tag in tact but the codes I was able to pull up none of them allude to axle ratio....Any thoughts other than pulling cover etc?
Yes...See Above....Its probably 3:23
Crawl under and see if the little metal tag is still attached to a third member bolt. Mine was on my '72, and it was a 2.76
Last summer I swapped to a 3.55 sure grip from Dr. Diff and now I'm half thinking I want to go back to 3.23 or 2.76 or something in between, since the new motor will have more than enough torque to do what I want, and I like driving on the freeway. Never ending projects... :rolleyes:
