Ggoodypaint
Greg goodson
I am desperately needing a picture of passenger side quarter window sitting in the track. just purchased a 72 cuda and the quarter windows are in a box help. it seems to have all the parts but need help assembling it. I have a body builders book but it’s just not clear enough. Greatly appreciate any actual pictures.
I can’t help with a picture, but if you look at the bottom of the window well you will see a bracket. That is for adjusting the track in and out. As for the regulator, the square support for the window crank obviously goes in the square hole, and you will see where the other bolts line up... a little fiddling will get you where you want to be..
rbbruno3
upstate , NY
This is probably not what your looking for. I can pull that panel off and take a pic behind it if that’s what you need
