Ground Wire Location
pfadool
Hi,
I have a '71base Barracuda 318 and the right side headlight, tail light, turn signal, brake light and emergency flasher all don't work. I have a feeling it's a ground wire issue but I don't know where that ground is. Any help is greatly appreciated!
Steve340
New Zealand
If all those are not working a single ground will not be the problem.
You may have 2 or 3 problems that is upsetting those circuits.
340challconvert
Parsippany, NJ
Check the condition of the turn signal switch. Brake lights, tail lights and turn signals all go through that harness. Make sure the wires coming out of the steering column from that harness are not damaged or burned.
Headlights sound like another problem and are usually ground from the headlight/ turn signal harness to the radiator support.
Steve 340 is right alluding to possible multiple problems to check!
wigger
I’m interested to hear what the issue was, I’m having the same problem
