Juan Veldez
Does the headliner insulation get spray glued (similar to the vinyl top) to the underside of the roof, or does it just lay on the headliner?
Ah, which way, glued?Yes.That's how I did mine.
No old headliner remaining. I have some of that spray. I'll spray the insulation, and the underside of the roof, allow it to dry until tacky, and then stick it in place. Thanks again!I Was looking for picture of old headliner.to see where it was cut for the bows. do you have you old headline to know where to cut? Here again I clamped and steatch for awhile to remove folds.
Sweet, I can wait. I plan to install that Sunday. Yes, I stuck the bows in and noticed that it needs to be cut/relived (sp?) back a bit.If you can wait.Ill dig out my old headliner and get measurements.If it's not cut in the right place it can be a problem. give me a day.
My car is a 4 bow. So, the one next to the dome light is non-existent. The holes are there for one, but this car came without that one. I should still be able to use your measurements though, I just skip that one - thanks.Measurement is cut to cut.Find center use half the measurement from center. go a little longer if you have any doubts. no problem if you have to go shorter. I think I had to cut one shorter.It seemed to tight.
I thought the bow sleeves needed to be cut back just enough for the bow end to clip into the holes in order for the headliner to remain tight up against the roof? If so, the lenghts from front to back are: 49",49",50 1/2", 67" for a four bow. If I am wrong about the relationship between the bow and sleeve, let me know, I can always cut more. And to confirm, this is for a Challenger, not a Cuda.Measurement is cut to cut.Find center use half the measurement from center. go a little longer if you have any doubts. no problem if you have to go shorter. I think I had to cut one shorter.It seemed to tight.
spry glue to roofDoes the headliner insulation get spray glued (similar to the vinyl top) to the underside of the roof, or does it just lay on the headliner?
used spray adhesive on both sides` 1st cut to fit between roof rails--pressed into place no problems--had pro install head liner. ,went from 4 bow to 5 bow--did not have to cut channels for bowsDoes the headliner insulation get spray glued (similar to the vinyl top) to the underside of the roof, or does it just lay on the headliner?
