Hood hinge dont work
Shut
FL
Hello to all,
In my 70 challenger the hood hinges dont work properly, cannt with the hood weight
The spring is The problem? Or the hinges complet??
Thanks and best regards
Shut
FL
Excuse me moparleo.
Well my hood hinges dont work. I need to change the spring or I need to buy a new (or refurbished) hinge??
Shut
FL
Thank you moparleo. I dont have car vocabulary to tell you the problem ;)
dongei
SW Florida
If the springs will not support the weight of the hood then it is possible that the springs are for a fiberglass hood. Have they all ways been that way?
Shut
FL
Yes dongei this is my problem!!!! Thank you
I buy the car recently and I dont know how are the car before.... She comes with a T/A fiberglass hood and the hinges dont support the weight of the hood
DetMatt1
Metro Detroit
So you have a fiberglass hood on it now and the hinges won't hold the hood open? Can you post some pictures?
Shut
FL
Yes Detmatt1 when arrive at home I post the pics. Thank you
Shut
FL
The pics
Shut
FL
I support the hood with a stick (to take the pics)
js29
lee center ny 13363
Judging from your pictures, the springs look to be light duty! with out being there, I would think it's your hing springs that are weak and won't hold your hood open.
challenger6pak
The hinges are weak because the hood is weak. If you put stronger springs on the hinge, the hood will warp and most likely break just after where the hinge makes contact with the hood. Choices are to prop up the hood, as mentioned, or replace the hood with a steel hood and add stronger springs to the hinges.
Shut
FL
Thank you!! Now I have the R/T hood installed... Then first Im going to buy the springs. Anyone knows the spring tension to buy it??
