Ignition Switch Rotates too Freely
Cav73
Maryland
I have a 1971 power steering column in my car 1973. The switch does not move sharply from one stop to the next when rotating toward start. It really just flops around. This was not an issue until recently, but I have noticed I now have to jiggle it to get the car to actually start - sometimes I get no ignition initially.
Does this sound like a switch that is giving up the ghost or is it possible to adjust or repair it? I have seen the column dissassembly videos and some of the threads on here. I may have missed a thread on this particular ignition switch issue.
If you have the tools, you should take the steering column apart to see whats going on. Like halifaxhop states you may need to replace the ignition switch. So either way the column will need to be taken apart.
Let us know what you find.
Thank you. I figured I would have to go there. I am trying to get my brakes working right so this will be the next project. Well, the horn is going off continuously so I have to sort that out even before the brakes - I am hoping I have the horn button pushed down too far and stuck or something. I wasn't having any problems until I took the steering wheel trim off (it's a 71 wheel).
Is it hard to find a 72-74 ignition switch? I have to start hunting for one.
I don't think its difficult to find an 72-74 ignition switch. I had bought mine years ago from Ebay but Classic Industries and Year One probably sell them.
Sound like timme to replace the switch itself?
Kill two birds with one stone!
Yes, that certainly looks like what I will be doing this fall...
Also, I took the trim and horn button off the wheel and that stopped the horn from blowing continuously. I would think I had the trim screwed down too tight, but I noticed that the circular black plastic part under the horn ring has an edge broken off. Also, I see sparks whenever I press the horn ring and the edge makes contact with the metal of the steering wheel.
I am guessing that ain't normal. The FSM does address that directly, but does indicate that the wire to the horn button switch could be grounded or the horn button switch could be grounded if a test light lights up if I hook it up to sockets 1 and 2 on the fuse block, wherer the horn relay plugs in. Or maybe the relay is bad now.
