installing a grille
I assume you have the correct header panel with 5 ribs behind the grille , the 2 piece plastic washer type inserts snap into the header panel first , these are almost impossible to remove without breaking them . Then the bolts go through the plastic washers into the grille .
Was the body just painted if so the plastic washer parts are probably not there ?
