interior paint
tbone
I have a 1973 barracuda with a green interior and I would like to paint my door panels but I
am having trouble finding an interior paint that matches the original color. Anyone have any suggestions on where to purchase interior paint?
Which green interior? To match what is in the car you will need to have some paint mixed up. Post a pic. I have the paint codes.
tbone
the exterior is GF3. Would the interior color be on the build sheet?
Pistol Pete
Check out Axalta (Dupont) Spectra Master line of flexible coatings. The color choices are mind boggling. The stuff is expensive but works well for vinyl and plastics.
The only green I am seeing is a Dark Green. The original Ditzler PPG code is 44696. The Chrysler code is AB61HF6. Most PPG paint stores can make this color. This is a low gloss color. The panels weren't painted from the factory. The original plastic look is between gloss and low gloss. A good paint supplier can mix it to match the gloss of your rear panels if you take one to them.
