Lower control bushing question
redwrydr
Northern Calif. foothills
Hi everyone, it has been a long time since I posted here, but I have a 70 Cuda, 383 and it has been about 3 years since I finished restoration, and now its time to get the front end back into shape. I have a question about the lower control bushing replacement. Do you have to remove the old sleeve for the new rubber bushing to be inserted in the lower control arm? The supply catalogs look like you can use poly without removing the sleeve, but I would sure rather use rubber if possible. Any help appreciated
Thanks!
Redwrydr
704406
Shawnigan Lake B C Canada
The lower control arm bushing is an assembly, outer sleeve, rubber bushing, and inner sleeve.
The rubber bushing is very tightly compressed in between the inner and outer sleeves, I think it would be impossible to assemble it yourself at home with out the correct jigs that the factory has, if you could buy the pieces separately which I don't think you can.
rarefish
Rochester, New York
If you are going with a rubber bushing, than you will need to remove the old remaining outer sleeve from the lower control arm. If you are going with a poly bushing then you would leave the old sleeve in.
I think now that there are poly bushings that are manufactured with inner and outer sleeves, just as the rubbers ones have been all along.
moparlee
Mid Michigan
Welcome back, but first you need to show us some pics :D. You have got to remove the outer sleeve left inside the CA. Buy Moog brand.
340challconvert
Parsippany, NJ
This may help
My Moog Parts list I used for my 70 Challenger front end rebuild:
Here are the part numbers I came up with for an order with Rock Auto for reference.
This "kit" includes idler and pitman arms, the UCA cam adjusters, and bumpers
Prices are from 2 years ago
ITEM PRICE_CORE_QTY_ EXT PRICE
MOOG K7041 Idler Arm $ 35.79
MOOG K7076 Pitman Arm 51.79
MOOG ES319S Tie Rod End Adjusting Sleeve (9/16")
$ 13.77 $ 0.00 2 $ 27.54
MOOG K783 Ball Joint $ 38.79
MOOG K772 Ball Joint $ 21.79 $ 0.00 2 $ 43.58
MOOG K5255 Stabilizer Bar Link $ 5.64 $ 0.00 2 $ 11.28
MOOG K408 Control Arm Bushing Kit $ 23.99
MOOG ES401L Tie Rod End (9/16") $ 15.40 $ 0.00 2 $ 30.80
MOOG K791 Control Arm Bushing $ 10.56 $ 0.00 2 $ 21.12
MOOG K781 Ball Joint $ 38.79
MOOG K7016A Strut Rod Bushing Kit $ 12.98
MOOG K5241 Stabilizer Bar Bushing Kit $ 5.79
MOOG ES401R Tie Rod End (9/16") $ 15.40 $ 0.00 2 $ 30.80
MOOG K8243A Cam Bolt Kit $ 13.75
MOOG K3180 Control Arm Bumper $ 5.94 $ 0.00 2 $ 11.88
MOOG K7293 Control Arm Bumper $ 4.70 $ 0.00 2 $ 9.40
redwrydr
This may help
Thank you so much for this info...I did see this in the archives, and it was helpful...will check the current prices.
