manual to power steering conversion '70 ebody
cuda8u
what parts do i need?
any pics of a power steering set up would be appreciated too
440 ebody
pls forward pics/info to MANTAY2xplornet.com
S-S-P
Texas
Steering box, P/S Pump, hoses, brackets, belt, perhaps a different pulley - depending.
I think the Pitman arm is the same. Not sure that you need anything else. I think it's a pretty straightforward change.
steering column is a different length as the power steering is taller so the steering shaft needs to be shorter , breaking the nylon pins & collapsing the shaft is not the best way to do this
