I am in process of cleaning and reassembling the steering coupler for my Challenger. I have a Steer and Gear power steering gearbox which I just bought a few years ago. It was in the car, and the column/coupler was attached to it, a year or so ago when I pulled out the steering column so I could rebuild my dash. The restoration shop that did the body on my car installed the column and apparently the gearbox/coupler connection was fine.
Background: The car is a 73 but the steering column and coupler came from a 71; however, I never had any trouble connecting the coupler and any gearbox before now (I had the 71 column in a 72 that I converted to power steering - that column went into this car as part of the resto).
Here is my question: I had trouble getting the column back into the car. The steering couple did not want to go on the worm gear shaft. Eventually I was able to coax it on part way, up to the gap for the roll pin. It would not go on further. I decided to pull it back out and clean and inspect the coupler, spring and shoes, which I did. However, I was surprised to see that the coupler does not seem to have an extra wide spline to match one I see on the worm gear shaft. I searched the site but I do not see something specific on this. Is the coupler supposed to have a wide "track" for the wide spline on the worm gear shaft? This coupler was definitely attached to the worm gear shaft for this box previously. I don't see any damage to the splines in the coupler, although the could use some additional cleanup with a bore brush. I did not count the splines in the coupler but I will do that tomorrow. I am wondering if there was some difference between years on these parts. Thanks!
