FOUND Need blower motor cage for heater only car
sedbld
Anyone have a plastic blower motor squirrel cage for a heater only car for sale? It’s stamped with part number 2837679. It’s from a 70 e body and measures approximately 4 3/8 across and 2 3/8 tall. I have one very close to the same size out of an abody but not as many fins and is metal. Thanks in advance. Mark
I have these. The 2 that are attached to working motors are in good condition. The one that is loose was on a non working motor and has a small piece that broke off around the arbor but I managed to get it off and I believe it’s sound enough to put back into service. It was difficult to get off.
$20 for the one that is loose and $50 each for the 2 still on the motors and you get he motors because I’m not removing the fans.
View attachment 143110View attachment 143111
Matt:
The A/C motors use a larger fan(and hence a different part number) than the non A/C ones. I think he is looking for a non A/C fan. What is the part number on those fans that you have?
Matt:
Yep, you’re right. I should’ve looked a little closer. These are all 2837695 and are just over 5.5” in diameter.
Thanks for the reply but those are too large. The non A/C , heater only cars used the smaller one that I need. So still looking. Thanks
