New woodgrain plate
Gísli Sveinsson
Iceland
Need little help here,
Should I use any special glue on new new face plate on cluster housing?
Steve340
New Zealand
I would use rubber cement. I used Elmers Rubber Cement.
It came in a small bottle with it's own application brush.
Gísli Sveinsson
Iceland
Here are my result,came out fine,expect odometer set pin is touching faceplate.
Maybe that normal,what do you think.
Gísli Sveinsson
Iceland
I have also 70 board and I will buying that faceplate from Performance Car Graphics.
They come ready and pre bended plate clued on.
I hope they are top quality.
Thanks.
MerlinsMopars
Detroit muscle has nice overlays and they suggest 100% silicone but you should be ok with other adhesive. Looks good!
ctaarman
One tip to folks bending these. I just did mine and you really only get one shot. So for practice, I took my old one and flattened it back out using a hammer. Then I re-bent it. Did this about three times learning exactly the right spot and bend angle so that it aligned perfectly with gauge openings. Then when I did my new one it was spot on and layed flat. Didn't need to tape it. I used a few spots of contact cement behind it before bending the clips, more for peace of mind than anything else.
