res1vw21
- Joined
- Dec 28, 2008
- Messages
- 135
- Reaction score
- 0
For the first 20 people in the month of October I am going to run a 10% off* special on door hinges for:
A body
66-70 b body
E body
F body
* does not apply to core charge.
Get them in quick before the 20 spots get filled up!!!
As some of you know I rebuild door hinges for people, recently I have had to change my methods a little due to parts supply but it is for the best because now they are stronger and better then ever before!
Pricing is as follows for any standard mopar: A,B,E,F
$70 a side (top and bottom) or $130 both sides (top and bottom) + $15 shipping for the return ride. $50 core charge will be added if bought outright.
What you get for your money:
The reason they are not greased is so you can paint them to match your car then use a spray lube type grease for long life.
Paypal only for the special
Thanks a bunch
-Ross-
Click for pics!
http://www.forabodiesonly.com/mopar/...02#post1256402
A body
66-70 b body
E body
F body
- Media blasted clean
- Epoxy primer in gray or left bare
- New pins in all hinges
- New brass bushings on both top hinges (except F which gets new pins)
- Star wheels removed, repaired and reinstalled
- New wave washers installed
- Springs repaired
- Assembled and and sent back to you labeled for position
Thanks a bunch
-Ross-
Click for pics!
