REAR Bumper guard Lower Bolt
R/T4ME
Richmond California
I am trying to figure out what size and Theard bolt is used in the bottom of the rear bumper guard for 1970 Challenger shown below.
It is the bolt that connects to the frame bracket, it is close to a 5/16 X 18 but that will not work.
I am thinking it must be a special bolt.
Matt
Matt
It shouldn't be a special bolt. It is probably 5/16 or 3/8. The captured nut in the unit may be stripped or the threads may be gawled
Matt
The rear bumper guard lower attachment bolt is a 5/16-18 with a 1/2" hex head.
Matt
Hey Matt, I'm not far from you in Santa Rosa. I can sometimes overthink stuff, and I encourage you to not overthink this. You are not going to find mysterious "difficult to distinguish" bolt and thread sizes on these older Mopars.
Take your part to your local ACE hardware or Home Depot hardware retail stores. They have this bolt guide you can use to determine the bolt diameter and thread count of your desired part, often visually just by closely comparing your threads to the guide.
Sometimes, on these older parts, that are rusty, you start to screw in a bolt and it gets tight, leading us to think we got the threads wrong, or something.
It looks like you don't post very often, so please let us know how it's going and if we can be of help.
I agree it's a 5/16" -18 bolt. Run a 5/16"-18 tap, using a tapping fluid, in there to clean it up. If it's galled, you don't need a broken tap in there.
Terry W.
Thank you everyone for the information. the 5/16 18 seemed close but since I cleaned all three of the ones I had with a battery terminal brush and it would not fit in any of them, I just wanted to make sure before using a tap on them.
Thank again
Mission accomplished It took more effort than i would have thought to chase the threads, so I am glade a checked first, but all three are cleaned up and functioning.
Since there were no bolts in these threads when I took the apart it might have been a combination of damage threads and years of road dirt.
Thank again
