Replacement Gauges
money pit
Has anyone replaced their stock gauge cluster with a Dakota Digital or the Auto Meter panel? Or has anyone replaced the old gauges with after market gauges? I would like to surface mont the gauges where the current water temp, Amp, and blank are currently installed. I'm would like to mount my gauges where I can monitor them easily. Right now I have an after market Auto Gage) oil pressure, water temp, and volt meter mounted under the dash, just above the center counsel. I guess I'm getting older and it's harder to see the gauges. Thanks
have wired up different gauge systems , there are a number of member who have done custom dash layouts , I like the twin gauges where you get 2 gauges in one as it makes ti more efficient for space
Do you know if I can remove the Amp, blank and Temp and leave the gas gauge in place? If so, I was thinking about cutting the gauge lens and I was going to place the Auto Meter gauges in the dash bezel. Thanks
These look awesome from Dakota Digital.
