Shaker trim ring
6PKRTSE
What is the width of a Challenger shaker hood trim ring around the exposed area when mounted to the hood? (The visual top side seen when the hood is closed).
I measured at the two middle studs, the opening is 20" across.
From the front notch to the rear of the opening is 24 3/4" long
measured on a Cuda shaker
Thanks. How about the actual trim ring width.
The ring is 2" wide, 20" opening so 24" wide total.
The ring is a bit hard to measure because of the upsweep curve built into it so I just measured straight across the width
