Shock Recommendations - Stock
jebirr
St. Louis, Missouri
Looking for some suggestions to replace shocks on my newly acquired 72 Cuda with 340. Going to keep it stock and lean more toward ride comfort rather than performance. Not for racing (or at least not much :) )
Seeing some poo-poo the KYB's and indications that they are a little stiff. Cost not a big issue but I'm sure there are diminishing returns.
Thanks,
Bilstiens or QA1 adjustable shocks. As I've posted before, there is a reason race teams have their own shock absorber sub-team, it's a key component in handling. The good shocks allow stiffness adjustment on both compression and expansion.
Koni shocks are good also. They are adjustable.
Went with the Koni's also. They are adjustable but not with a valve on the side so they appear more stock. Will have to repaint mine from red to black when the time comes.
The Bilstien Shocks give a nice ride. I’m pretty happy with them on my stock 70 Fish 🌴
All that being said. what are the part numbers of the shocks you bought?
I can't remember the part numbers but I know I got them easily from the Koni website.
KONI Special/Classic 80 SERIESs- internally adjustable, twin-tube non gas
Koni 82 1255 Shock Absorber Rear For 1970-1974 Dodge Challenger ?
Front Shock Absorber For 1970-1974 Dodge Challenger 1971 1972 1973 QS744BK?
How did you get the rear Koni shocks to fit the stud on the rear shock plates? The stock stud is too big to fit the rear Koni shocks.
That’s concerning, my plates are off having new studs put on, don’t have them in hand.
Assume there is a metal sleeve in the bushing? (Don’t have my shocks available)
I have Koni's on both my cars - fitted straight on.
Perhaps you do not have the right ones????
have viking double adjustable on mine love them best thing you can do is measure what length you need it might not be stock ride height . you don;t want them bottoming out there are plenty of web sights showing how to measure for them
@PLUM_72 Forgot I had an old one in the parts bin, the stud was heavily rusted and mushroomed out on the end. It was a really close think it would have gone on if it was in better condition.
Got my shock plates back, had the studs replaced with the Mancini parts, and low and behold the shock doesn't fit on the stud.
Can anyone measure and original one to see if there difference in the Mancini part?
