Solid State Voltage Regulator Conversion
Surfcuda
Palmdale Ca
I would like to convert my 1970 barracuda Voltage Regulator (3Wire) to a Solid State VR (2Wire). Is this a complicated task?
Also I currently have a RTE Internal VR installed for my instruments. I don’t know it this would interfere with a conversion.
Any help much appreciated. Please provide any guidance using the KISS (Keep it Simple) method because I’m electronically challenged. 🌴
After pulling the VR wires, I see that it is a 2 Wire connection rather than 3. I have attached a photo of my VR and one of my Alternator. I know Photos always help. 🌴
The 1970 Barracuda was originally equipped with a two terminal electronic, or solid state, voltage regulator. The pictured regulator is an aftermarket electronic, or solid state, voltage regulator.
The pictured alternator is a 1972 - 1977 "Square Back", isolated field alternator. The 1970 Barracuda was originally equipped with a "Round Back" isolated field alternator. The two alternator versions have two field connection terminals and are used with the 1970 and later electronic voltage regulator. The two versions are interchangeable. The following image shows the two versions:
Thanks Vaanth
Thanks Vaanth, great info on both VR & Alt. Appears my set up is already a Solid State VR. Would you agree?
My Alt instrument has been bouncing up to +C when I rev the motor. I believe it may be a bad VR. Any input would be welcomed 🌴
Thanks Vaanth
Yes, it is already a solid state voltage regulator.
The needle moving a small amount to the charge (+) side on the alternator gauge (ammeter) is not necessarily a bad indicator. If it is doing it too much, some measurements, checks, and possible tests are in order. The factory service manual provides detailed testing of the charging system including the alternator and voltage regulator, but the following is a short list of items to check or consider:
  • The gauge shows a charge, so basic health of the alternator is okay.
  • The varying charge with engine speed but without load changes indicates a possible regulation issue.
    • The regulator is powered by, and senses voltage at, the Ignition RUN circuit (blue wire).
    • If the sense voltage is too low, the regulator can drive the alternator field more resulting in over charge.
    • If the sense voltage varies too much, too much variability in the charge can occur.
  • Measure the voltage at the battery, at the alternator output, at the blue wire connected to the alternator field terminal, and at the regulator input (blue wire - easier to tap into it at the ballast resistor ignition switch side).
    • The voltages should be within one volt of each other at least; ideally around 0.2 volts difference is better. If the voltages do not check, high resistance is in the circuit(s). All wiring at junction points should be checked for good connections, including the following:
      • Battery post terminals to battery.
      • Battery post terminals to cables (internal).
      • Negative battery lead to engine ground, and body ground if present.
      • Positive battery lead to starter relay
      • Positive lead from starter relay to bulkhead, including dusible link and fusible link connecrions.
      • Bulkhead connections into and out of interior.
      • Ammeter connections.
      • Ignition switch and ignition switch connections, including connectors at the steering column.
      • Ignition RUN wiring from bulkhead to voltage regulator and alternator.
      • Ground connection through voltage regulator mounting screws.
      • Auxiliary ground lead from engine to body (firewall).
  • The green wire from the regulator to the alternator should have good continuity.
  • Field resistance of the alternator (between the two terminals) should be ~4-6 ohms. If higher, brushes may be worn or dirty. Worn or dirty brushes usually cause low charge though.
  • Ensure the battery is healthy. Fully charged without load, a healthy battery measures ~12.7 volts. However a specific gravity check of the electrolyte (if possible), is a more direct indicator. Specific gravity specification will vary depending on temperature and can vary depending on battery chemistry type. A battery that is beginning to get weak can cause more charge variation.
  • Quick check the charge capability by running the engine at idle. Monitor the voltage at the battery and the ammeter. Turn on the head lights on high beam and the heater blower motor on high. The voltage should initially dip, and the ammeter show a slight discharge. The voltage should recover as the engine runs. The ammeter should also move back to the center, fully or mostly. A carbon pile load is better, but this is a decent quick check. If it does not recover, a weakness in the system is indicated. If it over charges, a likely high resistance issue exists.
The foregoing are a few quick and basic things to consider. More in depth testing or checks as outlined in the service manual will provide more information if needed.
A bad battery can make the charging system act up. Bad cell or shorted.
This is kind of a long read.It will more than likely repeat some of the things Vannth covers.
Not that this is what is wrong but how to figure it out.
Alternator is probably going bad. When the battery is connected there is always power at the alternator. Ergo draining through the short in the alternator. That is the better possibility. There could be others.
Get the battery charged up and disconnect the alternator black wire over night. Or take out the alternator and have it checked.
Voltage regulator going bad? It needs a ground to work.
A bad battery can be a problem. You fixed that. At lest you think you did. A new one can be bad too.
When there is a charging issue. If it is showing discharge or overcharge. It is hard to say what the problem is until it is diagnosed.
This is for stock Mopar charging system.
1:With the key in the off position should have on the alternator output battery voltage.
2:The field wires should both read zero we should have no voltage.
3: If there is voltage at the field wires with the key off, there is a wiring problem.
4: If no voltage here at the alternator output with the key off then we likely have either a dead battery or we have a wiring problem or blown fusible link.
5: With the key in the on position. there will be voltage at the alternator output, it's going to be lower than what it was with the key off, because the entire vehicle is energized. The voltage drop is going to be more you can still see it go from
12 and a half down to 11.7. Still going to have near battery voltage.
6: What's important. With the key on. The field wires should have voltage. It won't be full battery voltage but it's has power coming to the alternator and it will be a lot less on one side and one side is high. That's the inlet so that's power going into the field windings.
The other one, the one that's low is the output from the field wingdings.
The output from the field windings is what goes back to the voltage regulator.
The voltage regulator on this is simply a switch ( Remember it needs a good ground to function.) all it's going to do is connect this field terminal here to ground and when it connects it to ground electricity then flows through the field windings energizing it and causing the alternator to charge.
7: Run test: This is for stock Mopar charging system.
Before doing the run test you're going to want to connect directly to the field output terminal on the alternator with some sort of a jumper wire. You can remove the existing field wire if it helps you to get to it. Use a jumper wire that comes back to the battery and it's not connected to anything right now. Have the voltage meter connected to the battery. Just checking battery voltage 12.3 volts there abouts. By touching the jumper wire to the negative terminal.
Just grounding it you can hear the engine load up because it's pulling a load and the voltage runs up to 14. That tells you that when the field in the alternator is energized it's charging. The alternator is good. Now you know that it's not an alternator problem at this point. If it's not charging you have a no charge scenario but this passes then you know it's the voltage regulator or some wire to it. It's most likely the voltage regulator and that's all it takes to diagnose the charging system on one of these
Here again If the any ground is bad or loose. it won't charge correctly or reliability. They become phantom grounds that just keep haunting you! That being the Voltage regulator ground, chassis ground, engine ground, Bolts, bolt holes, nuts and mounting brackets. 99% of the time there overlooked. The whole car is a ground.
That's all I have to say about that!
