Suspension question
Now for the rest of the story. ////
/// F70/14 Rim Width6 - 7” Section Width 8.75” Overall Diameter26.45” Rolling Circumference 83.10”
Rev./ Mile 762 Tread Width 6.55” /// 205/60R15
91H SL Tire Weight 22 lbs. Rim Width Range 5.5-7.5" Meas. Rim Width 6" Sect. Width 8.2 Tread Width na Overall Diam.24.7" Revs. Per Mile 842
/// P205/70R15
95T SL
680 A B 1,499 lbs. 44 psi 11.5/32" 22 lbs. 5-7" 6" 8.2" 6.7" 26.3" 790 /// P225/50ZR15
90W SL
40 B A 1,301 lbs. 51 psi 4/32" 20 lbs. 6-8" 7" 9.1" 8.7" 23.6" 881 /// 225/50ZR17
94W SL
340 AA A 1,477 lbs. 51 psi 9.5/32" 26 lbs. 6-8" 7" 9.2" 9" 25.9" 803 /// 225/55ZR17
97W SL
340 AA A 1,609 lbs. 51 psi 9.5/32" 27 lbs. 6-8" 7" 9.2" 8.7" 26.8" 777 /// P255/60R15
102S SL
400 A B 1,885 lbs. 35 psi 11/32" 32 lbs. 7-9" 7.5" 10.2" 9.1" 27.1" 769 /// P225/60R15
95S SL
400 A B 1,521 lbs. 35 psi 11/32" 24 lbs. 6-8" 6.5" 9" 7" 25.6" 813
And for the real rest of the story published tire specs are approximate.
Tire sizing is not standard in the industry. Only load capacity is regulated by the D.O.T. .
Take 4 different tire manufacturers and stand the same sizing of tires side by side and they will be + or - up to 3%.
This is one of the reasons that tires should always be matched in pairs on the same especially on modern cars with ABS brakes.
@bc3j Did you choose 15/16" instead of 1-1/8" to get the look you wanted or to get within the typical 24-25" fender height?
I am preparing to lower my front suspension. Fender lip is at 27" and definitely too high. Tire/wheel combo is Goodyear Polyglas GT F60x15 on 15x7 steelies.
That was the look I wanted. For curiosity I measured from factory locations. I’m running 235/60-15 all around. No problem rubbing or hitting anywhere. My wheels are also 15x7. I set fender height first for the look then measured factory locations just to see what it was. It didn’t matter to me what the actual number was, just got the look I wanted and had it aligned. It just turned out to be 15/16”.
@bc3j Thanks for response. I will do the same (pick what I like for height within reason) and then head to the alignment rack.
A little more on tire sizes.
Standard-Metric
Overall Wheel Diameter 78 series 14" Bias Ply 70 series 14" Bias Ply 60 series 14" Bias Ply 78 series 15" Bias Ply 70 series 15" Bias Ply 60 series 15" Bias Ply 75 series 14" Radial 70 series 14" Radial 60 series 14" Radial 75 series 15" Radial 70 series 15" Radial 60 series 15" Radial 50 series 15" Radial
21.8" - - - - - - - - 165/60 R14 - - - -
22.3" - - - - - - - - 175/60 R14 - - - -
22.7" - - - - - - - - 185/60 R14 - - - -
23.0" - - - - - - - - - 135/75 R15 - - -
23.1" - - - - - - - 165/70 R14 - - - - 205/50 R15
23.2" - - - - - - - - 195/60 R14 - - - -
23.6" - - - - - - - 175/70 R14 - 145/75 R15 - - -
23.7" - - - - - - - - 205/60 R14 - - 185/60 R15 -
23.9" - - - - - - - - - - - - 225/50 R15
24.2" A78-14 - - - - - - 185/70 R14 215/60 R14 155/75 R15 - 195/60 R15 -
24.6" - - - - - - - - 225/60 R14 - - - -
24.7" B78-14 - - - - - - 195/70 R14 - 165/75 R15 - 205/60 R15 -
24.8" - - E60-14 A78-15 - - - - - - - - -
24.9" - - - - - - 185/75 R14 - - - - - -
25.1" - - - - - - - - 235/60 R14 - - - -
25.2" C78-14 - - - - - - - - - 185/70 R15 215/60 R15 -
25.3" - - F60-14 - - - - 205/70 R14 - - - - -
25.4" - - - B78-15 - - - - - - - - -
25.5" D78-14 - - - - E60-15 195/75 R14 - - - - - -
25.6" - - - - - - - - - - - 225/60 R15 -
25.7" - - - - - - - - - - 195/70 R15 - -
25.8" - E70-14 G60-14 C78-15 - - - - - - - - -
25.9" - - - - - F60-15 - 215/70 R14 - 185/75 R15 - - -
26.0" E78-14 - - - - - - - - - - - -
26.1" - - - - - - 205/75 R14 - - - - 235/60 R15 -
26.2" - F70-14 - D78-15 - - - - - - - - -
26.3" - - - - - - - - - - 205/70 R15 - -
26.4" - - H60-14 - E70-15 G60-15 - 225/70 R14 - - - - -
26.5" F78-14 - - - - - - - - 195/75 R15 - - -
26.6" - - - E78-15 - - - - - - - 245/60 R15 -
26.7" - - - - - - 215/75 R14 - - - - - -
26.8" - F70-14 - - - - - - - - - - -
26.9" - - - - F70-15 - - - - - 215/70 R15 - -
27.0" - - - - - - - 235/70 R14 - - - 255/60 R15 -
27.1" G78-14 - - - - H60-15 - - - 205/75 R15 - - -
27.2" - - - F78-15 - - - - - - - - -
27.3" - - - - - - 225/75 R14 - - - - - -
27.4" - - - - - J60-15 - - - - 225/70 R15 - -
27.5" - H70-14 - - G70-15 - - - - - - - -
27.7" - - - G78-15 - - - - - 215/75 R15 - - -
27.8" H78-14 - - - - - - - - - - - -
27.9" - - - - - L60-15 235/75 R14 - - - - - -
28.0" - - - - - - - - - - 235/70 R15 275/60 R15 -
28.1" - - - - H70-15 - - - - - - - -
28.2" J78-14 - - - - - - - - - - - -
28.3" - - - - - - - - - 225/75 R15 - - -
28.4" - - - H78-15 J70-15 - - - - - - - -
28.7" - - - J78-15 - - - - - - - - -
28.9" - - - - L70-15 - - - - 235/75 R15 - - -
29.1" - - - - - - - - - - 255/70 R15 - -
29.3" - - - L78-15 - - - - - - - - -
So if my front tire size is 235/60/15 my ride height is 26.1 , is this correct , Im looking to get my front level , right now its 24 1/4 on drivers side and 25 on passenger .
Side-to-side tolerance is 1/8” so you need to even it out.
Changing ride height throws off your camber/caster so an alignment is needed once you have the ride height where you want it.
I was asking if the chart is correct that with my tire size the height should be 26.1 up front .
26.2" - F70-14 - D78-15 That's about as close as it will get to stock.
There are different tire and ride height combinations that are determined by the model. From what I seen.
I would say MoparCarGuy
answered your question as I understand it too.
What chart?
Ride height chart
Let me give you something. That is if you don't have it. There is no dumb question but the on that was never ask!
Ride height chartView attachment 152628
Standard-Metric
I was thinking this was a fender to ground height , this is tire size , correct , my bad .
There kind of is. A lot of others have used it for reference. They were not aware if the bumper height measurement. As I was also not aware of it too. Way back when. Keeping in mind everything is good when setting it up. Tires, tire pressure, shocks, size of torsion bar, there could be other things. Body alignment?
Now the question is…
Where do you measure the bumper height?
Dead center?
And the chart height of a Challenger bumper is different than a Barracuda. 😖
