Suspension
RT1
Does anyone know a company that makes components to upgrade the suspension on a 1970 Challenger. The car would be for street/strip.
burntorange70
Moderator
Aguanga,CA
Just Suspensions has some good stuff. What do you have to work with so far?
it depends what you want from the suspension , strip modifications generally hurt cornering , you have to know exactly what you want to get the suspension to work properly
RT1
I want to adjust the drivetrain and stiffen the suspension to go from a 383 to a 600-700hp Hemi mostly for driving on the street, maybe a few passes on the strip once in awhile.
the Stock suspension can work extremely well , re-inforce the lower control arms , change the upper to tubular , use Poly bushings , thicker torsion bars around 1" , larger sway bars front & rear as well as good shocks Like QA1 or Edelbrock , add some good tires , keep the ride height low so the rear springs sit flat & the car can handle extrmemly well . XV told me that 50% of the gains from their system on a car was from the wheels & tires alone
Rob C
Mid Florida
He he he, easy to ignore since everyone is not looking at an item they assume is just basicly more bologna advertisments.
ramenth
Beaver Dams, NY
That's true. Also doesn't help that PST doesn't post on here when they have new catalogues and deals going on like they do over on FABO.
