T/A Exhaust
etoyman
Guelph On. Canada
Hi Fellas
I would like to install a T/A style exhaust on my car '70 Chall
I have the mufflers, & Side exhaust pipes & tips, but not sure where they mount
Would anyone be able to provide any pics of their system
much appreciated
etoyman
They mount via a bracket that is attached to the rocker panel. It is located behind the rear floorpan, and in fron of the rear wheel well. I think that these brackets are reproduced. you will just have to drill holes for mounting.
T/A's and AAR's had a threaded plate welded in hehind the rocker, there were five holes total, they were place in an upward "v" pattern. Only three of the five holes were threaded and thats where the brackets bolted to. I would think that if you were to just drill holes then use self tapping bolts that you would be fine.
