Throttle linkage
drewkins
Mounds View MN
I'm putting an ld4b on my 1970 barracuda 318. Using a Holley carb and was wondering what i may need to hook up the carb to the stock throttle cable?
You will need to get the linkage for a 4 barrel. The linkage for a four barrel are longer than the two barrel so they will not reach properly unless you lengthen the kick down rod and raise the manifold mount by cutting and welding an extension. Or just check with companies like Mancini Racing that sell these parts. http://chucker54.stores.yahoo.net/trcabr.html
You may need the 20-7 linkage adapter depending exactly which carb you use
