Nov 27, 2021 #1 B Bama-man Active Member Joined Apr 6, 2021 Messages 44 Reaction score 19 Location Cartersville, GA Do the 4 bolts under the column have to be removed as well as the 2 bolts attached to the dash to get the wires down thru the column
Nov 27, 2021 #2 moparleo Well-Known Member Joined Oct 17, 2011 Messages 7,278 Reaction score 2,074 Location So. Cal. Riverside area Moreno Valley Complete repair instructions are found in the Factory Service Manual. Use it. Service Manuals – MyMopar mymopar.com
Nov 27, 2021 #3 C Chryco Psycho Well-Known Member Joined Dec 28, 2008 Messages 5,089 Reaction score 2,747 Location Panama Yes you need to remove the 2 bolts & the mount from the column under the dash so you can remove the plastic sleeve that protects the wires
Dec 3, 2021 #4 B Bama-man Active Member Joined Apr 6, 2021 Messages 44 Reaction score 19 Location Cartersville, GA Thank you I got it figured out
