valve covers
booyaballer
San Jose
I want to replace the valve covers on my 70 challenger which has a 360 crate engine. I've looked online and only AMD seems to have a set that have the breather holes in the center. does anyone know of any others with the same holes but cheaper? Thanks.
I assume that is because you are trying to make your engine look like a 1970? Those were used 70-71. Doesn't make much sense to a manufacturer to make them that way since they made the 318 and 360 for many years after and they all interchange.
Do you have a clearance problem with the air cleaner ?
I posted my set of 71 340 valve covers on FABO under Tonysrt in wanted 71 valve covers with pics in post 5. They look exactly like the AMD with maybe added straps. The post is old so I don't think it is open anymore, it was dated 12/26/2020.
The only reason i'm looking at the AMD ones is because in their picture, the openings are in the same location. everything i've seen on summit racing for example, the holes are in different locations compared to mine.
