What Torque Converter
BoomerSoonerVA
I have a rebuilt 440 bored .04. Mild performance cam, 3.55 rear end. Looking for a neutral torque converter 24 spline. I’m thinking 2400 to 2800 stahl. Any recommendations?
Basically the converter needs to match the cam .
If the cam starts to work at 2000 rpm then the converter in the 2400 range is perfect
if the cam starts to work at 2800 rpm 2400 stall will be a terrible choice as the converter will lock up before the cam is into the powerband .
SO you need to know what the cam is to choose properly .
Camshaft Use:
Street/Strip
Camshaft Manufacturers Description:
Fair idle, good midrange power camshaft. Requires 9.5:1 and higher compression, 2,000+ stall, and gearing. Good mild bracket racing cam.
Basic Operating RPM Range:
2,000-5,500
Intake Duration at 050 inch Lift:
224
Exhaust Duration at 050 inch Lift:
234
224 int./234 exh.
Advertised Intake Duration:
298
Advertised Exhaust Duration:
303
Advertised Duration:
298 int./303 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.466 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.488 in.
0.466 int./0.488 exh.
Lobe Separation (degrees):
114
This is a pet peeve of mine! I hate that the industry rates torque converters by Stall Speed. The same basic torque converter was used by the factory for slant sixes, 340s, 383 high performance and the 426 Hemi because the torque increased with each engine. In reality a torque converter from any of these engines would work great with your 440.
But per the modern Stall Ratings, the 2400 rpm stall converter will work great like @Chryco Psycho has indicated.
Now off my soap box.
